Contact Closure on BCD996XT
LANEWZ
La Habra Heights, CA
Hello, does anyone out there know if the BCD996XT’s 9-pin connector supports a contact closure or GPI output? And if so what pins do I use.
Need info in order to trigger a priory interrupt for an Emergency Alert System (EAS)
Thanks,
LANEWZ
K8TEK
Banned
Ohio
I don't believe it does. If you want to do something like that you are going to need a dedicated weather radio. They are cheap.
UPMan
In Memoriam
Arlington, TX
BC370CRS does have dry contact closures per the CEA specification. That is the only Uniden product that currently has full CEA1009A compliance.
LANEWZ
Thanks for the info. The contact closure is needed to force a UHF radio system to listen to a TFT EAS system that also includes NOAA weather service warnings. Guess we will need to get yet another dedicated radio :(
K4APR
Chesapeake, VA.
Regarding this feature, how is it triggered? DTMF? Two Tone? MDC? Just curious, might have some real uses in the commercial world, depending on how the dry closure is triggered.
ffexpCP
wizard of odd
Michigan
I don't understand what you are trying to do. Do you mean you want the EAS to listen TO the UHF? Are you trying to mix or scan your inputs?
UPMan
In Memoriam
Arlington, TX
It is triggered by EAS. As a fallback, if a 1050 Hz tone is detected but no EAS was detected first, it will trigger on the 1050 Hz tone.
