chrismol1
P25 TruCking!
- Joined
- Mar 15, 2008
- Messages
- 1,310
After reading the postings in a state forum on control channel modulation regarding trunking sites astro25 9600 control channel modulation C4FM vs CQPSK. I understand that simulcast sites are CQPSK(LSM) and ASR Astro Standalone Repeater fill in sites typically do not use simulcast? and are typically of C4FM modulation. How does the subscriber handle this? I've seen astro25 smartzone systems with sometimes neighbors as these standalone sites. Does it automatically switch modulation? Will a subscriber system programmed in CF4M see a decreased performance on a switch to a CQPSK neighbor site or a CQPSK programmed system see decreased performance switched to a C4FM neighbor site? Does the radio figure it out itself?
I've noticed in Astro25 XTS/XTL CPS it states
But then APX CPS it is revisedDigital Modulator Type (Trunking System, Digital)
C4FM: Compatible 4-Level Frequency Modulation for non-simulcast operation
CQPSK: Compatible Quadrature Phase Shift Keying for narrowband simulcast operation.
Note: This function is available to radio models equipped with CAI (Common Air Interface) Digital Operation.
WIDE: Wideband simulcast operation
Note: Cannot be chosen if a Channel Bandwidth of 12.5 kHz is selected.
The factory default is "CQPSK" forASTRO25 Trunking
The factory default is "C4FM" for Type II Trunking
C4FM
( Factory Default for Type II Trunking )Continuos 4-Level Frequency Modulation for non-simulcast operation.
CQPSK
( Factory Default for ASTRO 25 Trunking )Compatible Quadrature Phase Shift Keying for narrowband simulcast operation and non-simulcast operation.
This selection is only available to radio models equipped with CAI (Common Air Interface) Digital Operation.
