Control Channels??
scannerowner
NW Missouri
I was on 36 between Stewartsville and St. Joseph when I heard what appeared to be control channels or something on 453.425 and 453.475, it was constant but I wasn't getting very many bars, and know it wasn't LTR. . . can anyone else explain what this may be?!?! Also I heard 453.350 with a DPL of 754, and not sure who that may be, Lee's Summit uses that but has a different tone as well as Leavenworth, so I'm not sure. . . just gathering some thoughts!!
Starcom21
IL /MO/Global DB Adm!n
Were you possibly close to a radio tower and getting control channel noise from a 700/800 mhz TRS?
scannerowner
NW Missouri
I'm not too sure about how close I was to a tower, but it did sound like a control channel from a Motorola system, not P25. I'm pretty positive it wasn't a trbo system, because the only trbo system near by is in the VHF range not UHF. . .
talkpair
Clinton County, MO
I did a quick search between 453 and 454 MHz.......Nothing continuous found on 453.425 or 453.350.
I did pick up something on 453.475 and a similar signal on 453.925
These are both licensed to Kansas City Area Transportation Authority under KZT544 and KAB976 respectively.
They are both in the Jackson County, Missouri database here, with a mode of TELM.
scannerowner
NW Missouri
Ok that must be it, think I found those other frequencies you have listed, may have copied them down wrong sorry. Thanks for all the help!!
