Conversion questions
gcopter1
Winter Park, Florida
Prior to receiving a new G4, I downloaded PPS (v0.6.16.9) and set out to add the required info.
Not knowing any better, I created a profile with the tow truck G4 variant model number.
When I received my new G4, the model number is obviously different. No problem, I thought, I will convert the tow truck model to the new model.
However, no matter what I try, I end up with a "Programming failed" error message.
What am I overlooking?
I've already exported the profile to my desktop anticipating a reply to my problem.
Is there anyway for me to redo this without loosing any of my data?
BTW, pager shows PC Connected and the device shows up in PPS as well.
I've been able to read the new device as well so, no connection problems there.
TIA
N6ML
It's kinda hard to say what you're overlooking since you haven't described what you attempted to do :)
I haven't tried the TT model, but you should be able to go to tab C2 ("Copy from the Existing Profile"), then click on "Convert New Model" at the bottom, and select the correct model number.
gcopter1
What I am attempting is to convert all the worked I saved to a new model.
Remember, I created a profile previous to receiving the new G4, using the incorrect model of G4, so now, whenever I attempt to program, I get the failure message saying Cannot program the TT profile into the pager.
gcopter1
Notice the model number I selected to create the profile prior to receiving the new pager and the new pager model number below.
N6ML
Yeah, but you didn't say how you attempted to do it, so it's difficult to say what you might have overlooked. Anyway, try the above.......
gcopter1
Alright, let's see, I launched PPS, connected the new pager, clicked on E program from existing profile, clicked on next and a screen pops up as seen above.
N6ML
I clicked on Program and get this...View attachment 91437
OK, so what you overlooked is the need to convert the profile for your model number. See my original response. Hope it works on a TT profile - never tried that.
N6ML
Maybe it doesn't work for a TT profile then :(
You might try gradually deleting the knob positions and see if it starts working at some point. You may have to delete all of them, but at least (maybe) you can keep your frequencies and groups. I've never worked with the TT setup, so not sure what's different about it.
