Convert .PER to .PRS? Possible?
wa8pyr
Staff member
Lead Database Admin
Ohio
Can I convert an RPM .prs file to an older ProGrammer .per file?
No. Been awhile since I used Programmer, but it I recall correctly you can go from Programmer to RPM but not the other way. Ditto for RPM to RPM2.
BMDaug
I am licensed…
Central Colorado, USA
This should be right, but unless they fixed RPM2 this week, RPM2 won’t open any of my .prs files anymore.
-B
W4KRR
Coconut Creek
Thanks Tom. Turned out I didn't have to do that anyway. I put newer firmware into the older radio, then used RPM on both of them.
wa8pyr
Staff member
Lead Database Admin
Ohio
-B
If you're talking about RPM2 R16, they broke a number of things with that one; I won't go to it until they fix the boo-boos.
TDR-94
And changing the file extension won't work either. You can only import ProGrammer data into RPM, not the other way around.
