Convert TK-7180 file to TK 2180 file
stevez97
Myrtle Beach, South Carolina
Trying to save a BUNCH of typing in programming my newly acquired TK-2180.
I have a codeplug file already made for my TK-7180.
Is there a way to "convert" this file so that I can upload it into the TK-2180?
I'm waiting for a response with my fingers crossed! LOL
Thanks in advance for any help!
danielxgame
calgary
in your programming software just change the model from TK-7180 mobile to TK-2180 portable, you dont need to re type it or used the import/export.
kd4efm
Florida
Export the info, read the radio, import the file you exported, program if you dont want to change any thing.
Sent from my SM-G965U using Tapatalk
kayn1n32008
ØÆSØ
Sector 001
Do not forget to assign your button functions. Not everything is compatible between mobile and portable(like low power transmit).
danielxgame
calgary
Doing that will clear all info. KD4EFM has the correct solution.
in my experience, it will not clear the data the only will change is the setting for key from mobile to portable but the data will not clear.
N5XPM
Texas
This is very achievable as described above, but may be broken down into steps for easier implementation.
1) "Read" the 7180 mobile.
2) Save the 7180 file.
3) change the radio setting on the Kenwood programming software menu to TK 2180 from TK 7180.
4) Assign the buttons and TK 2180 -specific settings.
5) Save the new 2180 programming information file under a new name for the portable.
6) Change programming cables and "write" to the TK 2180.
The saved files save you time if it takes a time or two to make it all work correctly instead of unplugging programming cables to the mobile, etc.
stevez97
Well done N5XPM. That's exactly what I ended up doing, it just took me a couple of "trial and error" uploads to achieve the final result.
For the record, all the data WAS cleared, but it was just a matter of uploading the mobile codeplug into the portable-configured software. I tweaked up the buttons and the LCD settings and was good to go. Even with a couple of trial and error uploads, it still saved a TON of time.
Thanks to all for their assistance!
