COnvert txt into mem
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The .mem extension is used by the ARC series of programs from BuTel, such as ARC250, ARC780, ect. Probably others, too.
I THINK that what you would need to do is to import it to Excel, then copy/paste as needed. I'll have to look later at my ARC250 to see if it has a text import function.
73s Mike
rayveedub
.mem is for arc250, and ive done the cutting and pasting deal and it is not fun. why cant there be a easy button for this :wink:
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
A slight correction; ARC250 has a tool to import frequencies; you must copy/paste to get the rest.
Yes, it's not fun; and it's really hard to correctly import a text file, since there's no telling how the data is presented or in what order. To that end, there are a couple of other packages that have a better setup for this;
a. If audio recording is not an issue, then Scan Control is your best bet. In fact, if you are importing data from an older Uniden scanner or a PRO2052, Scan Control will upgrade the data automatically, so no text file conversions are needed. But it does have a very powerful text import tool that can import just about all the data you need, including alpha tags
b. I know Trunkstar 785 has a CSV import tool, but I haven't used that program, so I can't say how it works. This program has its own recording module, but it kinda has what I think of as a fatal flaw; you can't play back recordings made with Trunkstar with a standard .wav player. This is because a date/time stamp, along with some other info, in encoded into the file itself.
c. Radio Manager 2004 can import text files as well, but it's very finicky as to what happens if it finds a character it doesn't recognize; the import shuts down early. To do recording you need to purchase RecAll Pro seperately.
d. Scancat has it's own seperately purchased import tool called Magic.
Just a few possibilities here....73s Mike
Butelsoftware
Dayton Hamvention
Since ARC250 fully supports the Windows clipboard copy/paste there is no need for a text import option. Load the text in Excel and you can directlty paste any data into the ARc250 grid. Also you can easily move data within ARC250 with copy/paste.
Gommert
www.butelsoftware.com
USAPatriot
PRK
Gommert
That's true unless you attempt to alter the data once pasted in. I lost piles of tone data when I tried to move to the correct column. ALL the data simply reverted to negative numbers.
Al42
Long Island, NY, USA
Because you had the column formatted as General, not Text. That's how Excel is supposed to work. Change the format of the column first, next time.
