Hello. I'm relatively new around here so I hope I'm posting this in the correct area.
I did a search for this and found an older thread that partially addressed this issue but that thread was 7 years old so I thought I'd start a new one.
I have an older jeep that I use for ranch work. It already has a 102" Whip CB antenna with spring mounted on it that is not being used anymore. I was wondering if I could cut the whip down for use on 2 meters? If I could cut it to work on both 2 meters and 70 cm that would be even better. I know antennas for these bands are very cheap and it would probably best to just buy something new but since this mount is already there I thought I would ask. If it would work, what length should I cut it?
Thanks for your help.
