Converting Mocom Mic to Spectra
2wayfreq
NM Kirk City
I like the older MOCOM/MOTRAC style mic heads and wanted to re-use them on a more modern radio such as a spectra.
I was curious if anyone has taken older style mic heads i.e. the dark green Mocom ZMN-6022A or Flesh Colored/Red Button TMN-6013A and transplanted a spectra cable into the head? I am in the process of mapping out the wires to solder to the older ones. Any guide on the pin assignments would be great. Thanks
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Check batlabs.com for all kinds of info on Motorola hardware, new and old. I have found extensive resources there including pin-out's and schematics for the radios I am working with now. You will likely find the same.
cmdrwill
So Cali
Yes, most all Motorola mics have the same type of amplifier in them. In your case all you need is the cord from a Spectra mic so the connector is correct.
Motrac/ Mocom/ Micor and Mitrec and Syntor mics have this color code.
Red Mic hi
Blk Mic lo
Green PTT
White PTT return
2wayfreq
NM Kirk City
Cool!, Got it working!,good audio and the Dark Green "ZMN" Mocom Mic looks real good with the spectra connector. I soldered the spectra green and blue wires together to see if I get the HUB/Off hook (CSQ) function.
ramal121
Lots and lots of watts
Calif Whine Country
Unsolder the green and blue wires, that is going to get you nowhere. You need to connect the blue wire to the back button of the mic somehow. Maybe a small hole and tap a screw into it. Or pry up on the inside where the button is flared out, insert the wire terminal and peen it gently back into place.
2wayfreq
NM Kirk City
Woops,
That's right, the older Mocom mic does not have the blue attached to the button. I'll modify that and it'll be good to go. Thanks
jondeeres
help with useing mocom mic on a connex 3400 hp 4pin
Some of the other drivers I run with use the mocom mics on there cbs they are 4 pin and I bought one on Ebay it is a NMN6097 with 4 wires black red green white any help
