Copy EZ scan to 800
Kel
SW 2-18-26-W2
I am ready to transfer to scanner,do I press the button which says Copy Configuration to Scanner Memory/SD Card,or is there other steps first?Scanner has to be off?
DonS
Franktown, CO
No other steps. Just select that menu item. You'll be prompted to verify which "disk drive" is the scanner's microSD Card.
If copying over USB to the scanner - the scanner must be turned off.
