I have several 5061 radios I need to update programming for, I have a number of channels that need to be copied between multiple radios. Is there a way to copy and paste between code plugs ? When I try and open a second instance of CS-F3160/F5060 it does not let me and says that a copy is already running. I know I can open one file then copy 1 channel, then open the other code plug and paste the one channel, save, close open.... but that is quite a bit of labour for the 30 ish channels I need to do this with across a dozen radios...
Any Hints??
Any Hints??
