Coronado California Frequencies
rembisz
Hello all, I am new to scanning and am looking for help. I have a RadioShack Handheld Scanner Pro-96 (20-526). I have diwnloaded Win96 software and am a member of RR. I would like to program my scanner with freqencies from Coronado and nearby areas for police, fire, ambulance, highway patrol and any other interesting channels that are avaliable. I would like to be able to upload a file to the scanner to do this if that is possible. Thanks, Ron
Cokeswigga
Sure, Coronado is under the San Diego County RCS
Using your software, got to web import, radioreference, trunked systems
put in your login name,
select United States, California, San Diego County, then find the San Diego County RCS
I'm not sure which frequencies to get (maybe the south zone?), start with those and select the coronado talk group.
If you only want to hear coronado, then make sure you click the button for "Closed System"
dangitdoug
Fire Dept. and Lifeguards are analog. PD is digital. There is also North Island Naval Base. You might check the database for their freqs. I am on the other side of the county, so I don't have those immediately available as I don't listen to them.
Doug K
abqscan
DataBase Administrator
Moderator
AOA
Hi Guys, I'm programming a scanner for a customer, and I can't seem to find any FD TG's for Coronado. Any help would be great!
Thanks,
-Erik
