CP110 Programming
derota
Itasca County, MN
Is it possible to program a Motorola cp110 non-display model to a specific frequency? If so, please give me instructions.
rescue161
KE4FHH
Hubert, NC
Yes, it can be programmed to a specific frequency within the radios band-width.
You need the following:
1) Programming cable - RKN4155A - Motorola USB Programming Cable - $50.00 List
2) Software - RVN5149B - Motorola CPS R02.00 CP110 - $299.00 List
The software cannot be substituted and must be RVN5149. The programming cable can probably be substituted by using a cheap Ebay cable. I'm not sure on how much you can save, but this is one of Motorola's cheaper cables.
rescue161
KE4FHH
Hubert, NC
In short, no. You'd spend WAY more than it would cost to just buy the CPS and the programming platform.
Best bet, if you want to keep and use this radio is to purchase the above equipment. If you don't choose or want to buy the required equipment, then you should sell the radio and buy something else that is cheaper/easier to program.
