CP200D factory reset
BC_12
Merrimack New Hampshire
#1
Searching for a process to reset cp200d with digital capabilities to a factory default.
My ultimate goal is to set up as Analog only but no matter what I do they go into constant transmit mode. I hear the transmission on my mag one so know the freq was programmed.
If you can shed light on this I would appreciate it
BC
tdeater
Fremont, MI
#4
The Mag One's are a different critter. You have to do that button combo to get it into programming mode. I do not know of the CPS for the CP200's comes with blank codeplugs, you might look around the directory where it is installed in your computer and see if there is a factory sample one for that radio. A lot of the programs from Motorola come with sample codeplugs now.
N1GTL
CT
#5
You can default it to factory with a firmware update using the "recovery" option.
#6
The only problem with that is the model number has to match exactly and with the TRBO samples it will only give you 1 CP200d sample codeplug and whatever the frequency is is what it is. I believe the sample might be VHF with the digital option but i'm not sure.
GALAXY 19 91.0° W
#7
Never use sample code plugs. Most of them are built on very early versions of CPS. They can cause many byte mismatch and cause odd behavior of the radio.
