CP200D Programming cable question
12dbsinad
Can the CP200D be programmed using a regular generic micro USB cable or do you need the Motorola cable?
KG4INW
Midlothian, VA
I've had no problem using a generic one to program several hundred CP200ds but depending on the actual cable, you might need to carefully remove some of the outer plastic so it will physically fit the recessed jack.
kruser
Well Known Member
W St Louis Cnty, MO
That's exactly what I had to do in order for any of my micro cables plugs to seat fully into a CP200d and another device I have.
KG4INW
Midlothian, VA
When the radio first came out, we naturally bought the OEM programming cable but once we saw what it was, decided to try a generic one (had them literally all over the place) and they've always worked!
K2NEC
NA
Yup I just use my Samsung charging cable. Works well
