CPS 36 Excel import/export help..
UTLForlife
Hey yall, I am pretty new to CPS 36. I am just wondering the best way to get my codeplug exported into excel and do some editing then imported back, or at the very least the best way to add a few conventional personality. Thank you for your time and tips!
UTLForlife
Why export and edit if the CPS allows you to do..? Purpose of this is to remove certain areas of as codeplug instead of the entire file.
I was trying to get it into excel to more easily add a bunch of conventional personalities. Im finding that cps 36 is very slow and this takes a while. If excel is just there to remove parts of codeplugs then ill just type everything in lol. I'd figure there was a more ergonomic way to do this but it sounds like not. Thank you for the reply!
jeepsandradios
East of the Mississippi
CPS was never designed to export and import. It has abilities (xml) but in the end its faster to do it in CPS. I'm running 36 and have no issues with speed or slow once the porgam is open. In huge codeplugs its always been a bit slow. Guess it all dependso n pc and useage but thats been my experience.
Project25_MASTR
TX-COMU
Texas
It's slow...espeically when you start dealing with multiple P25 systems and 25+ zones.
PacScan
Los Angeles
It really does depend on PC specs, I have 40+ zones and it runs perfectly fine for adding and editing things. It is a bit slow when switching between systems. Nothing unusable though.
jeepsandradios
As of 15 minutes ago my NEXT has 179 zones, 42 trunkin systems...yup it take a second to change system or zone when i'm editing but its no slower than other versions I've used. YMMV...
I am running a work provided HP PC 13Gen 1.8G with 64GB of ram and 2 TB SSD.
Project25_MASTR
TX-COMU
Texas
It's agonizingly slow compared to Armada, RES or RPM 2. Hell, even Armada Server over a T1 is faster.
My current laptop is a 12 core, 32 GB machine with 256 GB of NVMe.
