CPS and Windows 10
awdauto
Hey everyone!
I'm attempting to program an HT1250LS+ with CPS on Windows 10 64 bit. I continue to get an error stating "Can not create unknown radio component". I'm running CPS R06.12.02 with a USB Prolific programming cable. I've rolled the driver back to 3.2.0.0, no joy. Tried uninstalling/reinstalling CPS. Nothing. Tried compatibility with Win 7, Win 8, Win XP SP3, nothing.
Any help would be greatly appreciated!
Ryan
N9IIT
Westfield, Indiana
I've never heard of emulating 32 bit on a 64 bit OS based machine. Since 32 bit machines are pretty common and can be picked up on the cheap even from a used computer shop you might go that route instead.
Project25_MASTR
Millennial Graying OBT Guy
Texas
You’ll need version R06.12.05 to run on a 64 bit machine or under Win10.
There were extensive discussion here a couple of years back about this. Easily found with the Search feature.
I still get that error with R06.12.05 on my last two issued laptops (running Windows 7 64 bit and Windows 10 64 bit respectively). My solution for the Windows 7 machine was to utilize the XP Mode VM which worked without an issue and allowed me to continue supporting Astro's, Pro's, 1225's and MTR2000s.
RightBatwing
Undisclosed, Middle East
The only way I run the older stuff is a VMware running XP, you will never ran into problems like that. I had the same bright idea until I hit one of my radios with R06.12.05 and then it required an entitlement key to program 25kHz bandwidth channels and that's a problem for ham radio. So I rolled back and cracked out the XP and shared some COM ports and never looked back.
