Cpu update - 10/28/16
WhistlerWendy
Northwest Arkansas
Good morning everyone!
There is a new CPU update available through the PC app.
This update will provide additional handling of RAS for DMR.
Happy Friday and HAPPY SCANNING!
gh6406
Dalton,Ga
CPU Updatre
Thank you so very much !!!! I have been fighting with (1) TRX-1 and (2) TRX-2 s for about a month now.
This update fixed my problem.
Anyone having issues with your scanner picking up DMR frequencies during Search, but will not stop on those frequencies when programmed in as a channel, this will probably fix your issues. Thanks again.
thanks
thanks .
I tried it but I find now if I land on a search channel it has no option to store channel.Am I the only one with this issue?
marcusabacus
Yes the store channel has gone on limit search and spectrum sweeper , also doesn't decode DMR in the sweeper..
1 step forward 2 steps back 😥
Melv7956
1 step forward 2 steps back [emoji26]
My dmr trunk systems have stopped working since the upgrade too.
JD21960
ILL-annoyed
CPU Update - 10/29/16 - 4.3
I'm guessing that 4.3 is the fix to put back the search store. A fix for a fix. I just found it and updated.
JD21960
ILL-annoyed
CPU Update 4.3 - 10/28/2016
Mine says *Store channel now. THAT was gone after 4.2 just the other day like the other's said above. This update came out 10/29/2016 - 4.3 I just saved a searched DMR frequency and it goes to the end of the default scanlist you chose. From there in "browse objects" I'm guessing you can change the scanlist and other things for it.
k3ygc
essex, md
cpu upate 10/30/16
another update today fyi not sure what it did..btw baltimore county md sounds much better on the 1080 lately.
D
DaveNF2G
Guest
Is Whistler field testing these updates before dropping them?
Ubbe
Stockholm, Sweden
TRX-2 have CPU vers3.3 at 28 oct as the latest.
Now the DSP levels actually does something with DMR. Setting it to 1 hardly decodes at all and level 75 do it just fine. Now begins the tweaking time.
/Ubbe
Melv7956
My dmr trunk systems were working again with 4.3 but missing chunks of communications and coming in mid conversation. I've reverted back to 4.1 and it's all decoding fine again and not missing anything.
oh my
Ok just to confirm that. 4.3 you had drop outs too huh?
Wonder what they did???
I'm leaving mine at 3.9.
