SCOTTER
I bought a 16 inch phonetone 7/9 dbi outdoor yagi antenna to help with my simulcast problem. After I got it I tried many spots around the house with not much luck,then at the end of the day I set it on the top of a bookshelf speaker that I have mounted 4 feet high in the corner of the living room horizontally and could not believe what I was hearing. I was a getting a 95% decode on my 436 thats plugged in the wall on the end table below it so that must be the hot spot so I mounted it above the speaker horizontally problem solved. About a week later my left ear started to have a ringing sound in my ear at night when I turned everything off for the evening,not loud but noticeable and I started to think that maybe having that yagi pointed at the couch is hitting me an the others that sit there and might not be a good idea or is my 54 yr self just getting old. BTW no one else has had a problem and Im not exposed to loud noise. So what do you guys think?
