Create 5130 LP
zguy1243
Calhoun Georgia
I just picked up a brand new Create 5130 Log periodic today at the local hamfest new in the box, and get this, the guy sold it to me for 10 dollars!! Here is the deal, i put the entire antenna together and it was missing the coax feed that connects to the antenna. It is a 39" inch piece of cable and some kind of plates that attach to the front of the antenna. So I have no way to connect cable to this antenna. Those of you with create logs can I get a pic of the feedpoint of the antenna? I need to either build or buy the antenna feed assembly for it.
Jody
zguy1243
Calhoun Georgia
Its a small world, Yeah I thought there was alot missing, turns out it was just the coax jumper the attaches under under the feed screws. I had a new one made with a female N connector. I had been told that Create changed the design on the newer models but it doesnt seem so. As this antenna is identical to another guys antenna and his is much older. Shes all to spec now. Enjoy your new antenna
Jody
