Hi there. Just picked up a BC396T with ARC396- I was in Mass. when I got it and loaded all the different CSP sites into different systems in the radio. What I am wonering is, as you drive up the Merritt from say Greenwich to 91/84 to the Mass Pike, what site would you use to listen? I played on the way down tonight and did OK...used 'Tolland' first and had 'Middlesex' on also- Toland seemed to be what it locked on to most of the way- think I had 'Windham' or some such on too. When I got further down I turned on 'Fairfield No' and that worked fine. When I got towards Wilton/Westport I switched to 'Fairfiled So' which was also fine.
So, did I hit it about right? Obviously I'll have to check out the Troop Maps.....also am wondering what Troop covers I-95 Greenwic to Westport and Merritt same span?
Thanks so much.
Phil
Thanks so much.
Phil
