Culver City PD
p20
I have a 785D and use to hear CCPD but no more???? Does any one kniow how to hear them?
I am trying
Base = 4780.500
Step = 12.5
Offset = 380
Freq
482.0625
482.1625
482.2625
482.3625
482.4625
482.5625
I am hearin what appear to be LASO/Compton and I am seeing talk gropu ID's (34576, 33616, 8272 and so on).
Any help would be greatly appreciated.
-Tom
Burbank, CA
#2
You mean the base of 480.500 right?
If you are seeing the talk groups but not hearing the correct channels, that is usually a problem with the base, step and offset settings. check all three in your bank and make sure they are correct (or the 1st one is correct and the second and third are blank)
Are you using a computer to program your scanner? If you are inputting it manually, make sure all those Culver City channels are reading "M" for Motorola trunked, and not Conventional. Might help to lock everything out that you might have in that bank also.
