thenewsden
Hi everyone,
Does Cumberland County no longer simulcast their EMS dispatch on 462.975?
see if you can hear 460.575 pl 100.0.
I sent an e-mail to the new Director of the Cumberland County Department of Public Safety asking if the change is permanent. It seems to be. The little bit of traffic I heard on the way in was on the new frequency.
Are they going to eventually move fire to that new frequency to replace the low band?
Their EMS dispatch seems to all be on that frequency now. Dispatch sounds a little muffled.
What is that frequency?
Sometimes, the signal isn't as good if they are on a different tower. The rushing sound...is it like you turned your squelch down the whole way? Have you checked your squelch setting? Do you have the CTCSS tone set? It should be 131.8. If so, then squelch level should not be an issue.
It was better today. I do not have a tone set. I'm not sure how to do that with my scanner. I have an old Bearcat Trunktracker.
What's the model number? It's quite possible depending on the age. I don't think there are any nearby agencies using that frequency, so interference shouldn't be an issue.
