I have two each PRO-10 & PRO-77 scanners. They are originally 8 channel crystal controlled scanners with incadescent bulbs to indicate which channel is active. The scanners are "identical", except that the PRO-10 covers VHF hi (147-174 MHz) and UHF (450-470 MHz) while the PRO-77 covers VHF hi and low (30-50 MHz).
I purchased the first PRO-10 in 1974 and the first PRO-77 in 1975. I originally modified each scanner to scan 16 channels and have single LEDs to indicate the selected channel. Over the next 10 years I acquired 2nd scanners of each model and redesigned their scanning logic.
I wanted individual switches for each channel on the front panel so I could "instantly" switch to a channel (the original design called for you to switch to manual mode and then advance one channel at a time to get where you wanted). Back then the best CPU I could get to do the job was an 8048. I was able to design it to scan 20 channels with the I/O available and drive a 2 digit 7 segment display. The units are still crystal controlled, but UHF is triple conversion! The scanners can operate on 110vac or 12VDC, but one issue I had with them was that the AC power cord could not be removed. I fixed that too and provided a LINE OUT where the cord was.
To this day it seems that Radio Shack (or GRE) has trouble calculating TWO SECONDS when it comes to a delay. My PRO-95 certainly does not delay for 2 seconds as it should (and neither does my PRO-92 when set to 2 seconds). So one more thing I added was an adjustable delay (with a pot - remember those?). There tons of other features written into the software I will not get in to here.
Pictures:
1. PRO-77 front (single unit)
2. PRO-10 and PRO-77 bolted together
3. Back of PRO-77 with power connector & line out
4. The guts (3 custom circuit boards) - also some dip switches to program other features still not available on any scanner I've ever seen over 20 years later.
George
Pictures:
George
