Cuts out every few seconds?
bfeeny
Royal Palm Beach, Fl
I have a BR-330T with latest firmware.
I monitor a Motorola II system, our local county (Palm Beach County) and I notice that when people are talking, about every 2 seconds, it quickly fades out and then back it, almost like they drop carrier, but they don't. I am not sure if its signal fading (every now and then I can see a signal drop out that coincides with this) or if this is behavior of the Mot II trunk system, or what. Another thought is that since I am inside my house on the rubber duckie (got a good antenna coming this week) maybe its my concrete block construction house screwing with the signal.
Is this normal?
captclint
Mountaintop, PA
Since you mention this only WRT a particular system, it is probably NOT Priority, weather alert, or Close Call, but just in case...
Dubbin
Findlay Ohio
I am almost sure that it IS one of those.
n2mdk
Ames, IA
Every 2 seconds is one of 3 things on a 330, Priority, Search or Close Call being active. Find whats turned on and turn it off. That will stop it.
bfeeny
Thanks guys, yes, I do run CC at the same time, and I mostly only scan this one system. I turned off CC and it went away! Thanks for the quick response..............I think I will run CC only when necessary :) Quite annoying with it breaking out every 2 seconds.
Brian
