Cws Tgid
NeFire242
Nebraska
I'll be in the Omaha area for the College World Series (CWS) and some other stuff going on.
I was wondering if anyone knew what TGIDs would be used for the CWS? I didn't take any notes from last year. Thanks!
Police probably will be on an event channel like B7. Listen to the common channels as well (C1-C3).
NeFire242
Nebraska
Ah ok thanks Nate. I was wondering if it would be a common or event, or if there was a hidden RBS one in there.
realgeo
Murray, NE
Good afternoon!
On the way home this afternoon, I heard several conversations on TGID 617 (B07) between mobile units and "Rosenblatt Command".
Looks like, as was mentioned before, B07 will be a good place to listen to for CWS traffic!
"PLAY BALL!"
73's
EMS is using C2 Common 2
OPD is using B8 LE Event 2 as well
The OPD Dispatch gets a hold of OPS at the CWS either by A3 Southeast or B7 LE Event 1
