Kenwood: D-104 mic question
k8niv
I have a Tug 8 base d-104, 4 wire mic, and like to wire it up to my Kenwood TS-590sg radio, does someone already have the wire colors of it did this before?
Have looked for the color codes, ect but nothing on this radio...need some help here,...
AK9R
Staff member
Super Moderator
Central Indiana
Color codes would only be of use if the microphone and your microphone cable always used the same cable and terminated them using the same color pattern. You'll probably need to use a VOM and ohm out the wires to see where they go in your particular instance.
The pin-outs for the mic connector on the radio are in the manual:
