There is already more than just ICOM that supports D-STAR...
DV-Dongle
D-STAR Hot Spot
Kenwood TMW-706 * But of course this one looks just like the ICOM ID-800 and hasn't been released in the US.
Do you use one of those DV Dongle thingys? If so, what is the computer software like? I presume the IP audio is just the same as the actual local radio audio because the "data" is the same either way (local or through IP). Is that the case?
If so, THAT is a real plus!
I have some ideas of what I would like to see on that. I would like it to be a Centracom console like interface!
It would be cool to be able to listen to several nodes (repeaters) at one time. Maybe with different levels of priority and volume on each with maybe a quick "focus" button to boost the level on something of high interest. FIFO scan with priority levels would be cool (You can't listen to too many stations at one time after all.). I would think it would be very possible. In that area you should be able to do nearly anything when it comes to software control. Emergency alerting and everything. The sky is the limit!
Like I said before, I love and prefer the big /\/\ gear, and I'm not crazy about ham toys that are hard to use and have bad audio and scan features, but the protocol and IP routing features make this a very versitile system with real "wide area" potential. I was never into the whole EchoLink/IRLP system because it is very intrusive, hard to manage, and a little like shooting in the dark if you are trying to reach someone in a different area...plus all of the listeners on both ends have to hear all of the controler noise. I can't stand that! And I was never a fan of using computers as a radio...like the internet was a DX tool :roll: , but I feel D-STAR changes all of that. It has real commercial grade feature potential. It is more like a commercial radio wide area system. I have yet to try some of this, but I hope it is not full of noise, automatic annoucements, and other controler generated garbage like many analog repeaters have. I would hope that all that extra "noise" is gone now that the routing is automatic and the call signs are all VISIBLE. No need for end-of-transmission "sounds" (simple built-in beep works), and no need to announce anything! I can't listen to repeaters that spit out useless noise and "sounds" for very long without locking them out.
The ability to close your monitor and listen for someone calling YOU is a real plus too. There are times you want to listen to a group or two, times you want to talk to a group or two, and times you want a silant standby.
Regarding the IC-91AD and it's scan and search features in D-STAR mode, it does well to pick up weak signals on scan/search. It does very well. I had allot of QSO action to test this today. The true dual band (dual watch) feature is VERY good, although digital is only available on band B. Two things bug me. 1) When I transmit, BOTH bands stop scanning and you have to restart them (one at a time) after every transmission. What a pain in the butt!
2) And there is no quick priority while scanning like big /\/\ radios, although there is the dual watch which almost serves this function...without digital. The sound quality is good, but the audio is WEAK.
Phil
