Damascus new LIC
milf
Careful, I CAN hear you!
Indianapolis, IN
#1
PW WQYR331
DAMASCUS, CITY OF
[CITY POLICE AND FIRE OPERATIONS]
Control Point 1 - 86 NORTH ROAD, DAMASCUS AR 501-472-4653
(link)
12/19/2016 License Issued
1 - 90 NORTH ROAD, DAMASCUS (VAN BUREN) AR [Structure: Tank] (map)
[Antenna 1 - HTT: 41.5m, HAAT: 96.8m]
155.6775 FB2 Ant: 1 40p 65e Units: 1 11K2F3E 7K60FXE
2 - 37.0 km radius around fixed location 1
155.6775 MO Ant: 1 50p 50e Units: 200 11K2F3E 7K60FXE
153.9125 MO Ant: 1 50p 50e Units: 200 11K2F3E 7K60FXE
Emissions for Analog and DMR, though only one of the 2 DMR listings, for voice no data, so I put this at an 50/50 on which way it goes. Also note, this is for both PD and FD, so if they do go DMR, one slot will be PD other slot will be FD.
03msc
Arkansas
#4
Interesting. The FD still are dispatched by both Faulkner & Van Buren counties. Sounds like it may be a local on scene channel for PD and FD..
Yes, it would likely just be their "private" channel - for dept operations, fire ground, and the like.
Keep in mind that having the license doesn't mean they will be using DMR immediately - several agencies have been licensed for a digital voice mode (DMR or NXDN, for example) and are still using their same analog channels a few years later. It's usually all about the money and when they can afford to take the plunge and upgrade all of the radios...
