Database admin
k4ktr
Elizbethtown,kentucky
Hello i have wanted to be a Kentucky db admin how do i do this who do i talk to i have strong ties to one of the current ky db admins Trash Man and he can vouch for me on my knowledge of Frequency info in the state
INDY72
Indianapolis, IN
Step one: Be a great submitter of continuous accurate factual information that is confirmed.
Step two: Have contact with at least the State Admin to develop a rapport.
Step three: Talk to THAT ADMIN about wishing to join the admin team.
OR: That Admin will put your name forward as an asset to the team.
Then things go from there. If you are lucky enough to get through and gain Admin status, do not expect to get the whole State off the rip. Usually you get a County or two/three and the State/Globals will see how well you do, and guide you on the way. Then depending on how it goes, you get bigger areas. I started out with 3 Counties in MS. Now I am trying my best to keep five States organized. Some days its like snapping a finger and I can spend hours doing what needs done, other days I barely have time to look at whats in my Que much less work it in.
k4ktr
Did not know that was any thing public I submit alot of info for ky THE KY ADMIN I KNOW DID NOT KNOW THE PROCESS TO BECOME AN ADMIN THAT IS WHY I ASKED HERE
dave3825
Suffolk County NY
He became an admin, but does not know the process?
k4ktr
He has been an admin since the late 90s and was unaware of how the process may have changed over the years back then it was not his well-defined has it is now. According to him back then you just had to take some kind of entrance exam
mikewazowski
Staff member
Forums Manager
Oot and Aboot
The Database Administrator Handbook would probably be a good place to start if you are considering becoming a database administrator. There is even a section covering how database admins are selected :).
Best answer right here. Read Section 3.5 and you'll have your answer.
If you feel you meet the criteria, then send a message to the Database Manager and ask for consideration.
Good luck!
