Database Map
STA75
Toronto ,OHIO
When I go to the Ohio database the County map does not show up this only happens on the state of Ohio. I'm using Vista if that is any help. thanks Rick
What Browser are you using? I notice with Google Chrome the database map has problems.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
I'm using Internet Explorer
If this happened to _ANY_ map, I'd suggest that it is an Adobe Flash issue for which you should completely uinstall Flash and then go to Adobe.Com and obtain the latest Flash.
However, if it is only happening in Ohio, it may have been a transcient problem with RR that was specific to the Ohio map. However, the Ohio map is currently working for me just fine.
So if it is still not displaying properly for you, I would consider clearing out all your temporary internet files, closing the browser, re-opening it, and revisiting the Ohio map to see if you can see it again.
Mike
