Date update
JRR4607
WACO TX
Does sentinel program update its date from radio reference? If so radio reference has updated new TGID in my city but not updating in sentinel. I have updated the firmware and master database.
rbrtklamp2
Dupage County, Illinois
When did you submit it and when was it posted? I think database pulls are every Monday for the SDS/X36HP radios sentinel program. You then have to go into sentinel and download the new database and write it to your scanner. Corrections to the database are not immediately ready for download and do not download themselves to sentinel you'll have to wait until Monday and see if your new info is on there. Download it and write it to your radio or check it in the sentinel software. The database version/date is at the bottom of the screen when you are using sentinel.
Sent from my SM-N910V using Tapatalk
hiegtx
Dallas, TX
Actually, Uniden pulls it's data on Sundays, then the database update is created and available normally on Monday mornings.
However, while you may have updated the Sentinel database, that will not update your Favorites list(s). That needs to be done manually if you are scanning a list instead of the full database.
If you are using the full database, and location, then the scanner would use the new information once the Sentinel database was updated and that update written to the scanner.
rbrtklamp2
So it still holds Sentinel only updates Master data once a week on Mondays ?
That's how I understand it how often do you need to update the master DB just put the new info into one of your favorites lists. I rarely of ever use the RR database.
Sent from my SM-N960U using Tapatalk
