SDS100/SDS200: DB9 pin female cable to Mini USB for SDS100
Kevdawg38
Bedford Ohio
Im looking for a cable for my SDS100 scanner. I bought the BC-SGPS unit awhile ago but all the extra cables I had were thrown away. I bought two from different companies but they dont seem to work, is there a place that sells this cable because I dont want to spend another 100 bucks for the GPS unit just to get a cable.
richardbritt
State of NC
Northeastern NC
Did you check here? Uniden sells replacement cables. If it's not listed on this page, call them. That way you are assured of getting the correct one
Regards
Richard
CollinsURG
This one worked for me.
Good thing is, if it doesn't work you can return it to Amazon. It is the cable that connects to the serial part of the GPS power box and to the SDS100. You can't connect directly from the GPS puck to the SDS100. Only the SDS200 and Beartracker 885 can do that. This cable will also supply power to the SDS100. You must also have the cigarette lighter plug cable that connects to the BC-SGPS power box.
