Decibel Products DB4140-2A VHF Notch Duplexer
Phoenix, Arizona
#1
I have been trying to locate a specification sheet for a Decibel Products DB4140-2A VHF Notch Duplexer. I'm interested in the frequency range, Minimum frequency separation and insertion loss. Normally I can find spec sheets for most DB Products duplexers but this one seems to be some what of a mystery.
Any information will be appreciated.
buddrousa
NW Tenn
#2
What is the intended input frequency and the intended output frequency?
The set on ebay from AZ Highway Department range from 150-156's and are very old. We had a set that worked 300Kz they were a lot larger and very expensive.
Phoenix, Arizona
#6
Thank you for the information sheet. I think this confirms my suspicion that the duplexer was constructed of individual filters and not as a set by the manufacturer. It should still work but I would be more confident if they were a matched set.
Thank you again for all your posts.
chief21
Summer - western NC; Winter - Tampa Bay FL
#7
I think the important distinction here is that this item is listed as a "Notch Filter" rather than a "Duplexer". A typical VHF Pass/Reject duplexer is much larger and usually consists of multiple filters. This device is a single filter and is apparently intended to notch out a single interfering signal. I don't think that I would attempt to use this with a repeater in lieu of a true duplexer (if that is your intent) as I'm not sure that you would get the necessary isolation between the transmitter and the receiver.
