Default Channel iDEN Data
Syncopations
Hears voices in my head.
South Texas
I'm trying to program a P25 trunked system into a P7100ip radio with correction feature option(39) using RPM. I ran into an issue where I can't save the system I created without an iDEN set. I do not know where to find this information, nor do I know how to create it. Can someone please help me?
If it helps, I'm programming the Lower Rio Grande Valley Regional Radio System(LRGVRRS).
Thanks.
LMR_Dude
Heres some default data for a 800 mHz system.
First, open SETS, then DEFAULT CHANNEL IDEN DATA
Click NEW IDEN SET and name it.
Enter 851.00625 in BASE FREQUENCY
Enter -45.0000 for TX OFFSET (MHZ)
Select 6.25 for CHAN SPACING (KHZ)
Select FDMA FULL RATE under TYPE
This should get you running.
Syncopations
South Texas
Thank you for your help. It worked out!
LMR_Dude
BASE FREQ is 762.00625
TX OFFSET is 30.0000 MHz
CHAN SPACING is 6.25 kHz
TYPE is FDMA Full Rate
ElroyJetson
Interesting theory I have not put to the test yet: Since you can program the TX offset, if you were to program an incorrect offset (not 45 MHz) then there's a chance that the radio could receive but never appear on the system, never log in, and never cause any problems.
Anyone care to test that hypothesis?
I'm not near any systems that are within listening range. Can't try it myself.
Radioman96p71
I've tried this, once the radio hears the CC it downloads the correct IDEN set(s) from the site and overrides what the radio has.
It's really only used to figure out the steps for channel scanning, once it hears a site the lovely P25 protocol fills in the rest.
wanabe
Would this also work for a 800 TDMA Phase 2 system with a p7200 with upgraded r02a firmware? TIA
