BCD325P2/BCD996P2: Deleting Close Call System
Al1009
Marshfield,MA
Somehow how created a Close Call System and gave it a system number of "0". How do I delete it? It doesn't show up in Systems when I use Proscan to download all systems and I can't find the where it is using the Menu on the scanner.
wtp
Port Charlotte FL
delete like you would any system.
and if needed or used it should come back.
menu, program system, yes, go tp the system, yes, go to delete system.
wtp
Port Charlotte FL
after taking a closer look that is not a system.
that is the close call settings.
i now bounce it back to the 'doc' for further thinking.
like how to take out the 0 setting or something.
Al1009
Marshfield,MA
Weird, it shows up on my scanner display as "0" but doesn't download in to the Systems in Proscan
wtp
Port Charlotte FL
you can't really get rid of close call.
it is a question of what you want it to do.
if you set it up to store a hit, there are two things that can happen.
you can tell it what system to put the hits in or it will put them in a close call system.
if it is not there it will create one for you and put them in it.
but with programming they probably have to build in a thing just in case it is not there.
that is a guess on my part.
Al1009
Marshfield,MA
I had to scroll up on the drop down menu to see the "None" option, it was hidden with "0" assigned to it.
