Is there a way to set Dept/Site quick key status. I can't find it. Searching found a post from @Butelsoftware where it was being worked on but that was a long time ago. Probably there somewhere but I haven't stumbled on it yet.
Well, I sure can't find a way to do this. I have to create FLs, load them in the scanner, open Sentinel and read the FL. Then I can set the needed staus on the Deps. /Sites and write them back to the scanner. @Butelsoftware are you still working on a solution to this problem?
Maybe I'm missing something. That looks like (and even says) "System QuickKeys Staus". As the thread title and my post states, I want to set the status on the Dept. quickkeys and or Site quickkeys that are within those systems. Setting the status of the System quickkeys is only part of the requirement to build a Favorites list. I need to turn on the default Depts. and Sites for each System within the list. I don't want all Depts, and Sites scanned when I turn on a System.
Hi Gommert (@Butelsoftware). I can workaround this shortcoming by building the favorite list in ARC, writing the list to the scanner, reading the list from the scanner with sentinel, setting the status of the Depts. and Sites, and then writing it back to the scanner but it is a pain in the butt. Any progress on this?
