Detecting Close Range Frequencies
#1
Are there any scanners on the market that can detect the presence of a certain frequency or frequencies nearby? I already know the frequencies, I just want to be alerted when they're nearby. How about on a busy frequency?
captclint
Mountaintop, PA
#2
Vast majority of scanners made within the last 4-6 years have frequency counters that only work at close range.
http://wiki.radioreference.com/index.php/Close_call
http://wiki.radioreference.com/index.php/Signal_stalker
http://wiki.radioreference.com/index.php/Spectrum_Sweeper
#3
LEH
Yorktown, Virginia
#4
You could dedicate a bank or system to those frequencies. If you have a PSR 500 you could set the counter on and see how often they are used.
Saint
Fort Erie Ontario Canada
#5
scanner
trafficninja said:
I already know the frequencies, I just want to be alerted when something nearby is using it. It needs to be specific frequencies. I don't think Close Call, for instance, would do that?
You could go on ebay and buy a cheap scanner for several dollars and have the frequencies put in this scanner and leave it scan all the time this is what I do for several frequencies I want to listen too all the time and not miss anything and not tie up my bc396t scanner.
Steve
Saint
#7
Scanners
Don_Burke said:
A cheap scanner with a lossy antenna or without an antenna would seem to fill the bill.
;) There you go !, I bought a Radio Shack Pro-2045 on ebay for $ 35.00 dollars and use it for several frequencies, police, fire, ambulance, coast guard, and a couple of others, it came with a little plug in back antenna and I leave it in the corner of the room running 24/7 and it works perfect.
Steve
Houston, Texas
#8
Most new scanners also have an audible or led alert for channels. I'm not quite getting what you would use this for though? When you hear a close frequency being used, most of the time someone is talking on it? So you would hear people's voices.
#9
Actually...I'm thinking APCO25 control channels. From my very quick reading on APCO25, it's my understanding that all radios in a talk group transmit to the zone controller on a regular basis via the control channels. I was thinking along the lines of the beartracker functionality of the BCT8/12 etc...
Is it true that all the radios in a talk group report their presence to the zone controller on a regular basis?
Toronto, Ontario
#10
Smartzone controllers ping idle (on, but not being keyed up) subscriber radios every four hours; I imagine APCO25 systems do the same thing.
I hope you realize that the inbound signalling on a control channel is very fast - you're trting to detect transmissions that last less than a tenth of a second.
