Determining EDACS LCN
transitman
Back of the Bus
Over the years I've seen threads regarding a method to determine the LCN for an EDACS system. Naturally when I needed to find those instructions, I couldn't. So can someone post the methodology or a link to a thread describing the process. I do recall that two EDACS compatible scanners are needed. Thanks for your assistance.
ElroyJetson
Basically it's a matter of listening and watching for an active channel and looking at the channel steering data until you correlate frequencies to active channels as they're being called up.
It's much easier when system activity is low. Late at night and NOT on a weekend or full moon night.
Having access to a spectrum analyzer with a hold function is very helpful. Even better if it has a waterfall plot function that allows you to record and play it back.
There is no simple formula for doing it. You just have to grind away at it until you don't miss any transmissions.
Or...there is a way. Check this site's database. If it's an EDACS system, those are end of life and being retired and new ones haven't come up in quite a few years. So the odds of this site having the required information in the database are very high.
cg
Connecticut
If you have the ability to use UniTrunker on the control channel and a regular scanner with all the frequencies programmed in conventional mode, it can go fairly easily. If the channels are used in sequence and you have a list of frequencies used (FCC data), you could figure it out in a few minutes of activity.
chris
