Diamond RCH77ca SDS100
SA_tx_88116
Rather listen than to stream
Cibolo, Texas
I planning on buying a diamond RCH77ca antenna for an sds100 I understand that I will need a Bnc adapter but which one, and is there any other stuff I will need to get?
dave3825
Suffolk County NY
If you have a lathe or a Dremel you can modify the SMA version as seen here.
Otherwise, the SMA to BNC adapter that came with the scanner will work.
This say it works if you do not have what came with the scanner.
