I'm thinking about trying out the Diamond RH-C77A antenna.. I hear it is real good with all-around reception. For the people that have used it on a Pro-97, are you happy with it? Also - who sells them?? Google came up with absolutely nothing.
Sounds good.. I will probably get it pretty soon.br0adband said:You could do worse, I assure you. For general monitoring, the stock duckie, the RS 800 MHz duckie, the telescopic whip, and an RH-C77A basically are all most anyone would ever need in terms of handheld antennas to monitor practically anything out there. The RH-C77A is a bit weak in the 800 MHz band so, that's why the RS 800 MHz duckie is also recommended as a backup if you need something more specifically tuned to 800. But overall, the RH-C77A is damned tough to beat.
10-4.br0adband said:Yes, yes, and of course.
I could be long-winded here like I usually am so I'll make it simple: Order one, right now, you won't regret it. .... But overall, the RH-C77A is damned tough to beat.
