Did Union County Monoc Tac 1 switch to
#2
That's a channel on Somerset County's P25 trunked system, along with that NAC. MONOC Tac-1 is 502.0875.
Taxachusetts
#4
N2ZGE
Roselle Park, NJ
#5
I never said anything about Monmouth County. However if you go into the db under UNION County, you would see the frequency is incorrect. Someone must have submitted an incorrect change of frequency I am assuming. It threw me off completely. I have been very busy with work but will try to submit the correction if I get a chance.
Taxachusetts
#6
Monoc seems to be used in Multiple Counties, hence the Tourist here, picking Monmouth (MON)... :roll:
