Did Union County Monoc Tac 1 switch to
Analogrules
I am hearing 502.6875 P25 NAC453. Did Union County tac 1 switch to P25 or am I hearing something else on the same frequency?
Joseph11
That's a channel on Somerset County's P25 trunked system, along with that NAC. MONOC Tac-1 is 502.0875.
Analogrules
Ok thanks for clarifying. Then the RR reference database is wrong because it lists Monoc Tac 1 as 502.6875. Someone should fix it.
ecps92
Taxachusetts
Analogrules
I never said anything about Monmouth County. However if you go into the db under UNION County, you would see the frequency is incorrect. Someone must have submitted an incorrect change of frequency I am assuming. It threw me off completely. I have been very busy with work but will try to submit the correction if I get a chance.
ecps92
Taxachusetts
Monoc seems to be used in Multiple Counties, hence the Tourist here, picking Monmouth (MON)... :roll:
Analogrules
I just submitted the correction to the DB. Thanks again everyone for the clarification.
