kb0nly mentioned in this thread that he likes to use dielectric grease between mating parts on outside antennas. The idea is to maintain the electrical connection, which the threaded fasteners typically provide, while keeping out water and corrosive compounds (particularly salt). Dielectric grease is a silicone grease. It doesn't "set up" like a silicone sealer does. It remains "greasy". You can usually find little tubes of dielectric grease in the chemicals and sealers section of your local auto parts store.
I used to have trouble with corrosion on brass parts of NMO mounts. Even with the O-rings or rubber seals that the antenna manufacturers provide, water and road salt would still work their way into the mount and corrosion would commence. A few years ago, I started using a dab of dielectric grease on the threads of an NMO mount when I attached the antenna. It seems to work pretty well to keep out the corrosion and I've detected no difference in the performance of the antenna.
Anyone else have other experiences with dielectric grease on antenna parts?
