Difference between IMBE and APCO-25?
human8472
I have seen different threads talking about IMBE and APCO-25 digital voice formats. What is the difference between the two? Where are they used?
mancow
N.E. Kansas
APCO 25 is the name for a set of standards. That standard happens to use the IMBE vocoder which is another way of saying a digital voice synthesizer.
human8472
Thanks for the reply. So .. would it be safe to say that just because a radio makes use of the IMBE vocoder does not make it a P25 radio? But if a radio was P25 compliant it would have to use IMBE for the vocoder?
KC2ZHY
Somerville, NJ
That's correct. The ProVoice implementation uses the IMBE vocoder, but is certainly not P25 compliant. It uses different modulation schemes, error correction, etc that is covered under the P25 standards.
For Phase I (FDMA) usage, correct. Phase II (TDMA) uses the AMBE+2 vocoder since it works better at a lower bitrate.
