I know it seems like it should be pretty self explanatory but I'm confused. When in stationary the scanner still scans all CC's programmed and constantly switches between weak and strong ones and I miss some conversations. I tried roam and it does the same thing, I would like the scanner to just lock on to the strongest one and stay there since I'm not moving anywhere. So I just switched everything to off, and programmed in the strongest CC in first so it stays there. I kind of thought this is what stationary would do it would find the strongest and stay there, while roam would stick with the strongest until the signal strength went below the thresh hold and then would move to the next strongest signal.
