eteves
Is there a difference between the thin, flexible Kenwood handheld radio antennas (left image, the one antenna photo) VS the thick non-flexible ones (right side, 5 pack)?
I've only really seen these thick antennas on Kenwood radios, none on any other manufacturer that I've come across.
I'm not even exactly sure that the thick ones aren't flexible but they look like they would be.
Is one a higher gain antenna or something of that nature?
If I am correct about the thick ones only pertaining to Kenwood, then if you've come across both of these types, I'm sure you know what I'm trying to explain here.
You can compare better in the bottom image between the two. Focus on the bigger radios in the back. Don't mind the small ones. You can see the one on the left with the thin and the two on the right with the thick.
See photos--
Thanks!
See photos--
Thanks!
