ST-Bob
ArcPatrol is designed for the Uniden HomePatrol scanner. It gets its data from a variety of sources including user input and the RR database. The information for each system is in similar columns to the RR dtabase but there appears to be some discrepancies.
This question is to find out whether regular users, premium users or admins see or have access to different levels of data which ArcPatrol seems to show and the RR database does not (apparently) show. Below is an example:
Massachusetts, Worcester County, Paxton
All 9 entries are shown as FM modulation though some of the frequencies appear to use different modulation schemes or bandwidths from my experience. The Paxton Fire VCall frequency 155.7525 comes in pretty garbled on my HP-1 when set to the default RR database setting of FM. Changing between FM, NFM, AM and Auto in ArcPatrol I was able to determine that this frequency is received clearly only when set to AM or Auto modulation. Auto is obviously something scanner-specific but appears to be somewhat flaky, mainly seeming to auto-detect analog or digital modulation, not AM, FM or NFM.
With the tight integration of the RR database into the HomePatrol and other new location-based preprogrammed scanners, is there something that needs to be changed in the display of the modulation types for the RR database?
Being severely limited in control panel options on the HP-1 I'm forced to play with the settings via ArcPatrol which was specifically written around the capabilities and limitations of the HP-1. It seems to have more optional data than the RR database contains (or at least more than it displays). Am I reading too much into this? Or am I just finding small errors which need to be submitted to RR.com?
