Digital / Analog Patch
DPS8504
Wichita Falls, TX
My communications facility will be converting to P25 Digital in the next month or so. We currently has dual Motorola Gold Radio Consoles. One repeater located at Decatur is already digital, with my main channel and a repeater at Throckmorton to be converted with in about a month. My question is that some of the interoperability channels will remain in the analog mode, can we patch the Digital and Analog channels together during pursuit or other emergency type situation?
thanks for your help.
WayneH
Forums Veteran
Super Moderator
Your master site
Yes, but the audio will sound terrible. Useable but the quality will suffer.
DPS8504
Wichita Falls, TX
We did some testing the past few days, the audio was pretty bad when patching the analog and digital repeater together. I hope it improves once we are all digital.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Interesting as we do it on a 3600 trunking system and it sounds just fine. You can tell the difference, but the audio is still intelligible.
DPS8504
Wichita Falls, TX
We are not trunked, conventional going to P25 digital. The Throckmorton repeater is 68 miles line of sight from the Control Station, the Decatur Repeater is 45 miles from it's control station and link to my console by microwave. The repeaters are a little over 90 miles apart. I don't know if the distance has anything to do with it, but the Troopers I talked to the other day said they could hear each other and understand what was being said, just a lot of static.
Once we switch over to digita, we will do some more testing.
Thanks for the replies.
mam1081
Next to a scanner...
How good is the link from the WF dispatch to the Decatur repeater? I've heard the dispatcher cut out on the repeater before - not something you usually hear.
Static? on digital? I wouldn't think the P25 vocoder knows what to do with that sound...
N4DES
South FL
OK...let me ask, how stable is the microwave link and is it analog or digital?
Could the issue be in the link and not in the recovered audio from the field units?
jparks29
John McClane
Nakatomi Plaza
One thing about digital communications.......
you either have a signal, or you don't......
there is no 'static' in digital radio, only no service, or missed packets (machine gunning,broken record, whatever you call it)
WayneH
Forums Veteran
Super Moderator
Your master site
You can still have chirping and robotic-like vocals. So it's not necessarily clear voice or nothing at all. I'd call that the 'static' version for digital.
grcjrsc
Elgin, SC
The term I've heard aroud here is "Space Talk"
jparks29
John McClane
Nakatomi Plaza
lol
yeah, exactly what I said ;)
