Digital decoding issues Unitrunker/DSD Plus
Tasmania
#1
Hi all, I am having issues with my digital on Unitrunker, I have it going from Unitrunker to a Virtual Audio Cable, then to DSD Plus, where am I going wrong as it won't decode properly and just sounds like static and only hear a few words that you can't even make out, is there anything else I need to install along side DSD Plus and Unitrunker for it to be able to decode it?
#6
For starters, are the analog signals coming in okay? I use VB Cable, it is much easier to use.
